Message 1 of 7
Frequent disconnection & slow upload speeds
Hi,
For the last few days, I've had frequent disconnections, which seem to occur every 30 minutes or so, but when the upload speed is very slow, at about 150/200kps, the connection seems stabilise and goes on for longer than 30 minutes.
I haven't changed any of my router setup but following this I've replaced the adsl filter  and the phone extension cable, updated the firmware on the router but it still seems to be happening and was wondering if anyone could advise.
BT have already checked the line and say there can't see a fault so it must be the internal wiring that is the issue
Thanks in advance for your help.
6 REPLIES 6
Message 2 of 7
Re: Frequent disconnection & slow upload speeds
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Message 3 of 7
Hi Keith_Beddoe,
Thanks for your message.
I've tried the quiet line test and can't hear any noise.
I've only replaced my phone extension cable today, therefore I'm not sure id the connection may need some time to settle so may disconnect now and again to begin with?
My router is only 2 years old so I am assuming it isn't the router that is the issue?
Message 4 of 7
Have you tried connecting the hub to the test socket with the new filter and eliminate the phone extension cable and see if that improves your connection stability
Message 5 of 7
Hi imjolly,
I've currently connected the router to the master socket and will see how it goes.
Thanks again.
Message 6 of 7
Hi,
Just an update regarding this- The router has been connected to the master socket for over an hour but in that time it has disconnected and reconnected twice.
Therefore I am assuming that it could be a router issue, or could it be possibly an issue with the cable connecting the router to the adsl filter?
Message 7 of 7
@confusedgirl100 wrote:
Hi,
You need to connect it to the test socket to see if the home hub still disconnects.
Which BT Home Hub are you using?
