Message 1 of 16
Can't play GTA Online with SmartHub2 - how can I fix it? (I can play it through my phone's hotspot)
I've recently moved house.
I took my SmartHub2 with me and my BT service and (after weeks of unresolved line faults), BT finally got my broadband working at my new house.
While I was waiting for the faults to be repaired, BT sent me a Mini Hub.  I was able to play GTA Online on that (on 2Mbps speeds).
Now that the Smart Hub 2 is working, I'm getting 40Mbps speeds (sometimes faster) but GTA Online won't connect.
When it gives me "cannot connect to GTA servers message", I disconnect my BT connection and use the data from my Giffgaff phone - this works too.  So there is nothing wrong with my PC/Firewall/Game - just with the Smart Hub - every works fine unless I use this.
I've done a factory reset on the Smart Hub to see if that would fix it - no change.
I've added the relevant ports to the portforwarding in the Smart Hub Manager to see if that resolved it - no change.
What is going on?  Why does everything in my house work except GTA Online?
15 REPLIES 15
Message 2 of 16
Re: Can't play GTA Online with SmartHub2 - how can I fix it? (I can play it through my phone's hotsp
Should mention - this is on PC
Message 3 of 16
have you turned of smart setup
Turn Off smart setup
Check MYBT and make sure web protect is turned off
Message 4 of 16
Message 5 of 16
Thanks for the suggestion.
I've turned Smart Setup off.
Web Protect was already off.
No change - still not connecting.  Using my phone's data via it's "hotspot" for now but it seems ludicrous that this Smart Hub won't let me play the game.
Message 6 of 16
Especially as it was working 4 weeks ago in my last house (exactly the same router, same setup, same distance from the PC, etc)
Message 7 of 16
Couple of other things you could try.
Disconnect the hub from line for about 30 minutes so that you get a different public IP address.
Try using Google DNS on your PC, 8.8.8.8 and 8.8.4.4
Message 8 of 16
Already had the Google DNS settings.
Will try to get another Public IP (have done this once already but not since turning off Smart Setup)
Trying to online game via a patchy 3G signal off my phone is making me lose the will to live
Message 9 of 16
Got a new Public IP address this morning (I checked - it's completely different).
No change - still can't connect
Message 10 of 16
just tried to connect to GTA online and black screen but it needed flashplayer to be active and once I activated flashplayer then I was able to access site
