Message 11 of 19
Re: Frequent disconnects and poor speed
Disconnecting all over the place when connected to master socket:
Went from 19Mb > 11Mb > 33Mb > 19Mb > 19Mb in automatic disconnections and reconnections in the space of 13 minutes.
Message 12 of 19
BT Smart Hub Manager
 Technical logInformation Event log
Save
This shows all events that have taken place on your BT Smart Hub since the last time it was reset.
Category: Select
Selected:  WAN
Previous = logList.length/pageSize - 1)}" tabindex="13" style="box-sizing: border-box; background-color: transparent; color: rgb(0, 71, 150); text-decoration: none; display: inline-block; margin-bottom: 0px; font-weight: 700; text-align: center; vertical-align: middle; touch-action: manipulation; cursor: pointer; background-image: none; border-width: 2px !important; border-style: solid; border-color: rgb(0, 71, 150) !important; border-image: initial; white-space: nowrap; padding-top: 0px !important; padding-right: 5px; padding-bottom: 4px; padding-left: 5px; font-size: 14px !important; line-height: 1.42857; border-radius: 3px; user-select: none; outline: 0px; margin-right: 40px; min-width: 100px; height: 22px !important;">Next
Page 1 of 3
Time and date / Message
18:23:11, 13 Aug.
:WAN: SENSING AUTO VDSL
18:22:36, 13 Aug.
ptm0.101:VLAN VLAN_DATA connected
18:22:36, 13 Aug.
:connection ATM_TV disconnected.[ERROR_USER_DISCONNECT]
18:22:36, 13 Aug.
:connection ATM_DATA disconnected.[ERROR_USER_DISCONNECT]
18:22:36, 13 Aug.
dsl:VDSL link Up: Down Rate=19085Kbps, Up Rate=4969Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
18:22:11, 13 Aug.
:VLAN VLAN_DATA disconnected
18:22:07, 13 Aug.
dsl:VDSL Link Down: duration was 333 seconds
18:17:13, 13 Aug.
18:16:35, 13 Aug.
18:16:34, 13 Aug.
18:16:34, 13 Aug.
18:16:34, 13 Aug.
dsl:VDSL link Up: Down Rate=19777Kbps, Up Rate=4976Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
18:16:11, 13 Aug.
18:16:07, 13 Aug.
dsl:VDSL Link Down: duration was 68 seconds
18:15:36, 13 Aug.
18:15:00, 13 Aug.
18:14:59, 13 Aug.
18:14:59, 13 Aug.
18:14:59, 13 Aug.
dsl:VDSL link Up: Down Rate=33237Kbps, Up Rate=6246Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
18:12:45, 13 Aug.
18:12:43, 13 Aug.
dsl:VDSL Link Down: duration was 26 seconds
18:12:18, 13 Aug.
18:12:17, 13 Aug.
18:12:17, 13 Aug.
18:12:17, 13 Aug.
dsl:VDSL link Up: Down Rate=11135Kbps, Up Rate=5044Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
18:12:00, 13 Aug.
18:11:56, 13 Aug.
dsl:VDSL Link Down: duration was 74 seconds
18:11:19, 13 Aug.
18:10:43, 13 Aug.
18:10:43, 13 Aug.
18:10:43, 13 Aug.
18:10:43, 13 Aug.
dsl:VDSL link Up: Down Rate=19941Kbps, Up Rate=4984Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
18:09:22, 13 Aug.
18:09:19, 13 Aug.
dsl:VDSL Link Down: duration was 52716 seconds
03:31:17, 13 Aug.
03:30:43, 13 Aug.
03:30:43, 13 Aug.
03:30:43, 13 Aug.
03:30:43, 13 Aug.
dsl:VDSL link Up: Down Rate=19911Kbps, Up Rate=4941Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
03:30:19, 13 Aug.
03:30:16, 13 Aug.
dsl:VDSL Link Down: duration was 1015 seconds
03:13:55, 13 Aug.
03:13:21, 13 Aug.
03:13:21, 13 Aug.
03:13:21, 13 Aug.
03:13:20, 13 Aug.
dsl:VDSL link Up: Down Rate=19911Kbps, Up Rate=4855Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
03:12:57, 13 Aug.
03:12:54, 13 Aug.
dsl:VDSL Link Down: duration was 1030 seconds
02:56:18, 13 Aug.
02:55:44, 13 Aug.
02:55:44, 13 Aug.
02:55:44, 13 Aug.
02:55:44, 13 Aug.
dsl:VDSL link Up: Down Rate=19838Kbps, Up Rate=4905Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
02:55:20, 13 Aug.
02:55:17, 13 Aug.
dsl:VDSL Link Down: duration was 1027 seconds
02:38:44, 13 Aug.
02:38:10, 13 Aug.
02:38:10, 13 Aug.
02:38:10, 13 Aug.
02:38:10, 13 Aug.
dsl:VDSL link Up: Down Rate=19762Kbps, Up Rate=4855Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
02:37:46, 13 Aug.
02:37:43, 13 Aug.
dsl:VDSL Link Down: duration was 1041 seconds
02:20:56, 13 Aug.
02:20:22, 13 Aug.
02:20:22, 13 Aug.
02:20:22, 13 Aug.
02:20:22, 13 Aug.
dsl:VDSL link Up: Down Rate=19941Kbps, Up Rate=4948Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
02:20:00, 13 Aug.
02:19:56, 13 Aug.
dsl:VDSL Link Down: duration was 1031 seconds
02:03:20, 13 Aug.
02:02:45, 13 Aug.
02:02:45, 13 Aug.
02:02:45, 13 Aug.
02:02:45, 13 Aug.
dsl:VDSL link Up: Down Rate=19911Kbps, Up Rate=4933Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
02:02:22, 13 Aug.
02:02:18, 13 Aug.
dsl:VDSL Link Down: duration was 5585 seconds
00:29:48, 13 Aug.
00:29:13, 13 Aug.
00:29:13, 13 Aug.
00:29:13, 13 Aug.
00:29:13, 13 Aug.
dsl:VDSL link Up: Down Rate=20060Kbps, Up Rate=4937Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
00:28:50, 13 Aug.
00:28:46, 13 Aug.
dsl:VDSL Link Down: duration was 23754 seconds
17:53:26, 12 Aug.
Previous image resolution went awful due to upload file size restrictions
Message 13 of 19
These fluctuations in connection speed in such a short space of time are terrible and I think need engineer visit to correct the reset problem which in turn will give you a speed within expected range
Message 14 of 19
It just disconnected again whilst in master socket with filter and router just kept flashing pink/purple. Left it doing that for 4-5 minutes and it didn't reconnect.
I've put the 5C MK4 faceplate back on and it's connected slightly better... but I doubt it will last:
Product name:
BT Hub 6A
Serial number:
+084316+NQ62300563
Firmware version:
SG4B1000E020
Firmware updated:
02-Apr-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 0 Hours 4 Minutes 9 Seconds
Data rate:
5.31 Mbps / 24.92 Mbps
Maximum data rate:
5309 / 26502
Noise margin:
6.2 dB / 6.3 dB
Line attenuation:
39.4 dB
Signal attenuation:
28.4 dB / 39.4 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
2 MB Uploaded / 96 MB Downloaded
Message 15 of 19
I had two engineers come out together on  Wednesday 5th August. They said they had it working fine but when I checked it was at 20 down and doing this disconnecting/reconnecting thing.
BT then sent me a new router on Friday 7th August. Had the same problems with that.
Monday 10th August an engineer came out, connected a brand new line (pulled new cable from telegraph pole and drilling etc), left the connection working seemingly OK, and took the router with him. The issues re-emerged a couple of hours later so I contacted them the following day as they'd left their number in case of problems.
Tuesday 11th August the engineer returned and connected the other router, did all tests, hence the 42Mb on that dsl checker on that date, and left. 12 hours later and it started dropping again.
So in the space of a week there have been 3 engineer visits, a new phone line, alternative routers used... it's affecting the whole family not being able to settle to watch online tv, films, or gaming because the signal keeps dropping and films stop playing or get booted out of games.
Message 16 of 19
that's terrible and you still have a poor speed  I have asked mods to see if they can help but they are really busy so could take more than the normal few days for mods to contact you
Message 17 of 19
Thanks for pointing this out @imjolly.
@Piratew,
It looks like we'll need to take a closer look at this for you. I'll need your details so I've dropped you a private message so you can get in touch.
Cheers
David
Message 18 of 19
Bizarrely, when you messaged me I went to open it and it had disconnected. Checked router stats when it reconnected and:
DSL uptime:
0 Days, 0 Hours 1 Minutes 54 Seconds
Data rate:
7.37 Mbps / 39.52 Mbps
Maximum data rate:
7450 / 38413
Noise margin:
5.1 dB / 5.2 dB
Line attenuation:
34 dB
Signal attenuation:
33.8 dB / 34 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
434 kB Uploaded / 2 MB Downloaded
I thought "Wow that was a quick resolution". As I just started typing my answers to your PM it disconnected again and now reconnected at:
DSL uptime:
0 Days, 0 Hours 7 Minutes 57 Seconds
Data rate:
5.37 Mbps / 24.79 Mbps
Maximum data rate:
5367 / 26152
Noise margin:
6.1 dB / 6.3 dB
Line attenuation:
39.6 dB
Signal attenuation:
28.5 dB / 39.6 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
3 MB Uploaded / 18 MB Downloaded
Aaargh!!
20:05:03, 13 Aug.
20:04:28, 13 Aug.
20:04:28, 13 Aug.
20:04:28, 13 Aug.
20:04:28, 13 Aug.
dsl:VDSL link Up: Down Rate=23871Kbps, Up Rate=5367Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
20:04:11, 13 Aug.
20:04:07, 13 Aug.
dsl:VDSL Link Down: duration was 136 seconds
20:02:26, 13 Aug.
20:01:52, 13 Aug.
20:01:52, 13 Aug.
20:01:52, 13 Aug.
20:01:52, 13 Aug.
dsl:VDSL link Up: Down Rate=38807Kbps, Up Rate=7372Kbps, SNR Margin Down=0.00dB, SNR Margin Up=6.00dB
20:01:34, 13 Aug.
20:01:30, 13 Aug.
dsl:VDSL Link Down: duration was 2797 seconds
Message 19 of 19
There is obviously a line problem as your attenuation is jumping about resulting in the speed fluctuations. Hopefully mods will help you get it fixed
