Message 1 of 6
Full fibre alternative router/hub?
Hi. I just had full fibre installed but I was thinking about exchanging the hub for something else but unsure what to get.  At the moment it comes into the house and goes to a little open reach box, the straight to the BT hub.   Will the TP-Link Archer A7 AC1750 Be ok? Or can you suggest a better option. My budget is £100 max.  Thanks
5 REPLIES 5
Message 2 of 6
Re: Full fibre alternative router/hub?
Your choice is pretty limited with that sort of budget, the Archer A7 will be ok. Depends what you are trying to achieve by replacing the hub.
Message 3 of 6
When you received FTTP did you also get digital voice?  If so you still need to use the SH2 for phone
Message 4 of 6
Hi. I don’t use home phone so just the hub at the moment.  I can go a little higher price if something is good.   I’m mainly looking for a better router as my sons and I have gaming pc’s etc.  Thanks
Message 5 of 6
What is it about the SH2 that isnt suitible for gaming?
Message 6 of 6
It’s been a bit unreliable.  It keeps resetting it self.  My last hub done that too so I thought an after market one would be more stable.
