Message 11 of 16
Re: Geforce now bandwidth throttled?
Well that is a new tool to add to my books!
Message 12 of 16
Big old dump from cports
24/06/2020 16:51:07 Added GeForceNOW.exe UDP 0.0.0.0:54687 *:*
24/06/2020 16:51:07 Added GeForceNOW.exe UDP 0.0.0.0:54688 *:*
24/06/2020 16:51:07 Added GeForceNOW.exe UDP 0.0.0.0:54689 *:*
24/06/2020 16:51:07 Added GeForceNOW.exe UDP 0.0.0.0:54690 *:*
24/06/2020 16:51:07 Added GeForceNOW.exe UDP 0.0.0.0:54691 *:*
24/06/2020 16:51:07 Added GeForceNOW.exe UDP 0.0.0.0:54692 *:*
24/06/2020 16:51:09 Added GeForceNOW.exe UDP 0.0.0.0:54693 *:*
24/06/2020 16:51:09 Added GeForceNOW.exe UDP 0.0.0.0:54694 *:*
24/06/2020 16:51:09 Added GeForceNOW.exe UDP 0.0.0.0:54695 *:*
24/06/2020 16:51:09 Added GeForceNOW.exe UDP 0.0.0.0:54696 *:*
24/06/2020 16:51:09 Added GeForceNOW.exe UDP 0.0.0.0:54697 *:*
24/06/2020 16:51:09 Added GeForceNOW.exe UDP 0.0.0.0:54698 *:*
24/06/2020 16:51:09 Removed GeForceNOW.exe UDP 0.0.0.0:54687 *:*
24/06/2020 16:51:09 Removed GeForceNOW.exe UDP 0.0.0.0:54688 *:*
24/06/2020 16:51:09 Removed GeForceNOW.exe UDP 0.0.0.0:54689 *:*
24/06/2020 16:51:09 Removed GeForceNOW.exe UDP 0.0.0.0:54690 *:*
24/06/2020 16:51:09 Removed GeForceNOW.exe UDP 0.0.0.0:54691 *:*
24/06/2020 16:51:09 Removed GeForceNOW.exe UDP 0.0.0.0:54692 *:*
24/06/2020 16:51:11 Added GeForceNOW.exe UDP 0.0.0.0:54700 *:*
24/06/2020 16:51:11 Removed GeForceNOW.exe TCP 192.168.1.205:51647 185.136.68.153:443
24/06/2020 16:51:11 Removed GeForceNOW.exe UDP 0.0.0.0:54693 *:*
24/06/2020 16:51:11 Removed GeForceNOW.exe UDP 0.0.0.0:54694 *:*
24/06/2020 16:51:11 Removed GeForceNOW.exe UDP 0.0.0.0:54695 *:*
24/06/2020 16:51:11 Removed GeForceNOW.exe UDP 0.0.0.0:54696 *:*
24/06/2020 16:51:11 Removed GeForceNOW.exe UDP 0.0.0.0:54697 *:*
24/06/2020 16:51:11 Removed GeForceNOW.exe UDP 0.0.0.0:54698 *:*
24/06/2020 16:51:13 Added GeForceNOW.exe TCP 192.168.1.205:51653 80.84.161.199:443
24/06/2020 16:51:13 Added GeForceNOW.exe TCP 192.168.1.205:51654 80.84.161.202:443
24/06/2020 16:51:13 Removed GeForceNOW.exe UDP 0.0.0.0:54700 *:*
24/06/2020 16:51:15 Added GeForceNOW.exe TCP 192.168.1.205:51656 185.136.68.153:443
24/06/2020 16:51:15 Added GeForceNOW.exe UDP 0.0.0.0:60031 *:*
24/06/2020 16:51:19 Removed GeForceNOW.exe UDP 0.0.0.0:60031 *:*
24/06/2020 16:51:25 Removed GeForceNOW.exe TCP 192.168.1.205:51653 80.84.161.199:443
24/06/2020 16:51:25 Removed GeForceNOW.exe TCP 192.168.1.205:51654 80.84.161.202:443
Message 13 of 16
You have your IP addy now. 185.136.68.153
Message 14 of 16
WinMTR statistics
Host%SentRecvBestAvrgWrstLast
router.asus.com01011010000
172.16.13.3301011014454
81.139.57.1738723310101010
81.139.57.172010110110101111
host213-121-192-52.ukcore.bt.net010110110101111
166-49-209-132.gia.bt.net010110110114411
212.119.4.140010110111111211
213.130.47.118010110111123412
185.136.68.31010110111111412
185.136.68.153010110111111212
Message 15 of 16
Nothing wrong there.
Message 16 of 16
What is wrong is GFN network test detecting packet loss and lower than expecetd bandwidth
https://community.bt.com/t5/BT-Fibre-broadband/BT-Capping-bandwidth-to-geforce-now/m-p/2083246/highl...
WinMTR does not use same packet size, packet type or packet frequency as what GFNs own native network test uses.  GFNs own native network test is optimised for GFN service - winMTR is not optimised for GFN service  and so does not accurately replicate network stress in GFN traffic scenario.
What is described at
 in this thread should be marked as solution as using VPN removes zayo.com from route and seems to make GFN network test happy.
For discussion what is described in OP here is very similar scenario as what is described in OP at https://community.bt.com/t5/BT-Fibre-broadband/Horrible-ping-spikes-and-packet-loss/m-p/1915395
which is described in more detail at
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Is-My-BT-Internet-Connection-Suitable-For-Next-...
Different cloud gaming services are detecting packet loss and lower than expecetd bandwidth.
Can anybody show that what is described at
https://community.bt.com/t5/BT-Fibre-broadband/Horrible-ping-spikes-and-packet-loss/m-p/1916928#M283...
can help all cloud gamers and not just those who use Shadow cloud gaming service?
I find it odd that nobody in BT community has suggested that requesting the "super stable" option on their internet connection can help make GFN network test say "You are all set for streaming" instead of "Streaming over your network is not recommended"
BT do not throttle traffic but it may prove to be the case that they can optimise customers connection to better meet the demands of cloud gaming services.
As far as i know no other ISP offers customer the choice of "standard", "stable, or "super stable" options on their internet connections.
