Message 1 of 4
Getting my noise margin reset?
Hi there, I need a moderator to reset my noise margin. We have found the issue being the filter in the line had packed up. We've waited 3 days now just need it all resetting if somebody could
Here's the logs:
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
3 Days, 5 Hours 17 Minutes 27 Seconds
Data rate:
799 kbps / 2.00 Mbps
Maximum data rate:
3726 / 18810
Noise margin:
16.6 dB / 32 dB
Line attenuation:
28.1 dB
3 REPLIES 3
Message 2 of 4
Re: Getting my noise margin reset?
As you are on adsl2 and not vdsl the DLM should release the banding automatically in3/7days  if no improvement after 7 days connected post back and we can see if mods can help you
Message 3 of 4
Hi @johndeereboy1 thanks for posting, I'm sorry to see you're having problems with your broadband speed. Your connection is definitely capable of much more than 2Mb according to the stats.
As long as the underlying issue has been sorted we'll be able to get that reset, I'll send you a private message so you can send over your details. You'll get the private message by clicking the envelope on the top right of this webpage.
Neil
Message 4 of 4
Hi @johndeereboy1, thanks for taking my call earlier today and just to confirm that the speed has improved and the noise margin reduced automatically earlier today.
cheers
John
