Message 1 of 6
HELP PLEASE Unstable speeds Ranging from 1 mbps to 20 mbps was fine before switching to BT?
Not sure what information you guys need to help me? Activity log?
InformationEvent log
This is a list of your BT Smart Hub settings and current statistics.
Product code:Smart Hub 2
Serial number:+091298+2035029305
Firmware version:v0.21.03.07094-BT
Firmware updated:Mon Nov 23 00:04:08 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:1 days,02 Hours50 Mins03 Secs
Data rate:1.745 Mbps / 22.227 Mbps
Maximum data rate:1.745 Mbps / 22.930 Mbps
Noise margin:6.2 / 3.4
Line attenuation:13.3 / 29.2
Signal attenuation:13.3 / 30.1
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:926.9 MB Uploaded / 7.5 GB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-Z5AKF3
2.4 GHz wireless channel:Smart (Channel11)
5 GHz wireless network name:BT-Z5AKF3
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:On
MAC address:E4:75:DC:03:87:C0
Software variant:-
5 REPLIES 5
Message 2 of 6
Re: Unstable speeds Ranging from 1 mbps to 20 mbps was fine before switching to BT?
You have a connection speed of 22Mb. How are you testing your speeds. wired or wireless?
Have you turned off smart setup?
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
Message 3 of 6
Yes at this moment it is fine but it fluctuates i have ran the speed test on both wired and wireless conmections. The reason the problem has come to light is through the use of my PS4 Ping rate spiking massively making it unplayable and also big drops in speed which is affecting my partners working from home.
When the ping spikes i run a test of speed and its barely registering 2 mbps, i ran the tests through speedtest.net
Ive now turned off smart setup? Is it known to cause issues?
Message 4 of 6
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 5 of 6
I dont actually currently have landline phone, i will try sort something and do as you suggested. Thanks for your help on the matter 🙂
Message 6 of 6
Yes smart setup is notorious for causing issues. Leave it turned off.
A cheap corded telephone is the best diagnostic tool you can have as line noise accounts for over 90% of most broadband problems. If you detect noise on the line it's a line problem not a broadband one.
Line issues generally get fixed quicker.
