Message 1 of 5
Halo 1 broadband offer
I have just been offered the new Halo 1 upgrade for free on a 24 month contract I am already paying BT for phone rental plus broadband over a telephone line on which I get 38mbps.
for me to take up this offer I need to know I am going to get a significant upgrade in regards to MBps.
I am a home worker who connects to my work network via a VPN which cuts my broadband speed down to 18.5mbps which is not quick enough to run everything I need run smoothly on the work network
Halo 1 looks to be fibre optic based so I'm assuming  because BT has made me this offer I am linked up to accept broadband via a fibre optic cable.
presuming all the above is correct does anyone know what kind of increased in bandwidth I can expect to receive in regards to download speed
I will be connecting to the hub via ethernet cable as I'm guessing that Is better than connecting via Wi Fi
Thank you for your assistance
Tags (1)
4 REPLIES 4
Message 2 of 5
Re: Halo 1 broadband offer
Halo 1 is just an add-on to a broadband package and does not give any speed increase. You already have FTTC with 38mb connection speed.  Is the upgrade you mention to FTTP or just to Halo 1?
Message 3 of 5
HI Thank you for your quick reply
as far as I can tell they are just offering me the hub however it does say the Halo 1 Fibre Hub but there is no mention of connection to a fibre network or any speed increase
Message 4 of 5
Enter your phone number HERE to see if you can get FTTP. If you can't there will be no increase in speed.
Message 5 of 5
Thanks for directing me to this phone number checker as it showed me that FTTP is not available to my telephone number..hence there is no need for me to accept the offer for Halo 1 as there will be no increase in speed for me
