Message 1 of 6
Hi, we are having huge trouble with our Halo 2 Hub. Worked fine for the first few months now, the last 2 days it’s been switching off, every 2 hours virtually, and takes upto 20 / 40 mins to reset every time. Happens all times of the day and night. Makes working from home tedious.
have sent a complaint via email, not heard back as yet.
we have done all the trouble shooting suggested, we have checked the speed and line, all ok.
no local faults ..( me9 Kent.)
We had some snow, can this affect it?...? No neighbours affected though...
I wish we could rectify this, quickly! it’s so frustrating.
the lights on the hub, go from purple/pink flashing , then orange flashing.
any Advice is most welcome. Thankyou.
5 REPLIES 5
Message 2 of 6
Re: Halo2
When you you have done all the checking did you do quiet line check to see if any line noise?  Did you try using the test socket with a filter to see if that improves stability
which master do you have
Message 3 of 6
Re: Halo2
Hi, yes we just did the quiet line test, and it actually sounds like a loud hum.?
we have no. 3 socket. (Old)
thankyou for such a quick response...
Message 4 of 6
Re: Halo2
Did you do quiet line test with a corded phone or cordless. If corded should be silent
have you tried removing faceplate of master socket and connect to the test socket to eliminate the faceplate and internal wiring as causing problems
Message 5 of 6
Re: Halo2
The line test we did on a cordless phone, certainly wasn’t silent.
so, do we just unscrew front plate then?  Is there another socket inside then to test it.......?
thankyou.
Message 6 of 6
Re: Halo2
So we’ve just take front plate off, and plugged straight into the point,
Re checked phone line , much improved, much quieter.
Wifi back on, will see how stable it is from now...
Here ‘s hoping! Thanks for your help so far, much appreciated.
I guess we will need an engineer to come fit a new box,possibly?...
