Message 1 of 14
Fibre halo2 speeds just dropped by 2/3
Every time I get my speeds sorted they drop a couple of months later. Engineer came Feb 21. For my speeds back to expected 48 download and 15 upload.
then 17th April the smart hub manager says firmware update. It now shows upload 16 and download 1.2
Checked using 192.192 etc on browser
and sure enough that’s the maximum I am now getting. It’s like BT have capped me again
my package is fibre 2
also the by speed checker now shows receiving 15 download is meeting my expected package which implies My package details have been ammended incorrectly.
I am fed up having to report and get engineer every couple of months.
13 REPLIES 13
Message 2 of 14
Re: Fibre halo2 speeds just dropped by 2/3
Could you post the hub stats from Advanced settings/technical log/information.
Is there any noise on your line? 17070 option 2, best with corded phone, may get a dull background hum from cordless.
Message 3 of 14
I have attached a screen shot of what I think you mean
we don’t even have a phone now.
the engineer suggested last time that if we don’t use the phone then take it out as can cause interruption ?
Message 4 of 14
can you try connecting your hub to the test socket with a filter and repost hub stats
test socket is behind the master socket faceplate
Message 5 of 14
Hi. Thank you.
I haven’t got one as not using phone line anymore but will borrow one today and come back to you when I can test this. Thanks for help
Message 6 of 14
Message 7 of 14
I have an idea you may find no dial tone when you borrow a phone to test. The internet will work if only 1 wire is connected but will be slow.
Let us know when you try the quiet line test.
Message 8 of 14
Hello.
thank you for all your help. Yes I have managed to find an old wireless phone and charge and connect it. There is no dial tone.
Also on the smart hub manager it has the phone symptom greyed out and says not configured?
I pay for a line so don’t know why it would just disappear over the last week ?
BT engineer is coming to do a remote visit tomorrow so should they just pick this up?
Also do you mind if I ask you something just for my understanding. On the 192.192 browser page,  when I look at the Smart Hub manager and it says downstream sync speed.... when this says 16mbps versus 49mbps from last month... is this the hub telling me the maximum by hub can receive or is it telling me the maximum BT will let it receive. Some people in the last have told me that BT can control this to cap what you get?
I just want to understand it as sometimes the engineers give me different answers and this is the 4th time in 18 months I have had to get an engineer
thank you
Message 9 of 14
Unless you had digital voice then the phone number is always greyed out
The speed you see in hub manager is your connection speed and should  be best your line can handle unless like you have problems with your line   you would like your connection speed to be very  close to your attainable speed  only restrictions BT impose is the maximum speed for your chosen broadband package - 55mb for fibre 1 and 80mb for fibre 2
Message 10 of 14
Thank you so much. You have been really helpful
