Message 1 of 5
High error count?
Hi all, just wondering , I’m getting 4,000 few errors per minute, should I be concerned?
usually got around 1000 per day
4 REPLIES 4
Message 2 of 5
Re: High error count?
*FEC errors
Message 3 of 5
Hi @w4481 and thanks for posting.
You'll find some great information on FEC errors and what they mean at the Kitz site . Take a look and let me know if that helps.
Cheers
David
Message 4 of 5
Hi,
thanks for reply. Was a few open reach vans down the road the other day and corrected errors is fine now, crc and es count practically gone. Was correcting around 20000 errors an hour now around that per day . 30 es and around 50 crc, so all looks well now 👍was obviously an external fault that openreach has sorted
Message 5 of 5
That's great to hear @w4481 . Thanks for letting us know.
All the best
David
