Message 1 of 3
Home Hub 2
Afternoon all,
I have the above hub.I,ve connected my television into a spair ethernet port via powerlink adapters to my my Television, Works fine. I want to connect my Sky Q main box by the same means to one of the other ports left on the router.If I do this do the ports work or do they have to be enabled any way?
2 REPLIES 2
Message 2 of 3
Re: Home Hub 2
the SKYQ box should work fine as soon as you connect to ethernet port on hub
Message 3 of 3
Re: Home Hub 2
@imjolly  Thanks for the prompt reply.Thought that was the case but wanted to be certain.Just need to st the Qbox onto ethernet.
Again thanks
