Message 1 of 2
Home hub 2: Airplay disconnecting
Hi,
Hoping someone can give advice please.
I have a home hub 2. Fibre to the door in a new build property.
I have a problem using airplay to my Naim Muso qb2  It  works fine when listening to internet radio, but whenever I use airplay to play music from my phone or ipad, it disconnects after a while (the time varies). It becomes invisible on the network for a few minutes and then reappears. If I restart the router, it works better for a while, but then does the same as described after a while. I am sure it is not the Muso as I have tried  a couple of factory resets and it has made no difference
Any advice to solve this would be great.
Many thanks.
1 REPLY 1
Message 2 of 2
Re: Home hub 2: Airplay disconnecting
Actually a Smart Hub 2.
Couldn't find where to edit my title.
