Message 1 of 4
Home hub not allowing connection
Good morning! I’ve just moved to a new house and am waiting for openreach to set us up, which I believe may be some time... my neighbour has a home hub 2 which I can see is putting a good signal into our property. He has allowed me access to the hub and I have all the details to login.
However, none of my devices seem to be able to log in to the hub.
Am I doing something wrong? Normally once you have the ssid and the Wi-fi password, I should be able to connect to any Wi-fi router right? Or is BT different?
many thanks
3 REPLIES 3
Message 2 of 4
Re: Home hub not allowing connection
@Langers123
That's very kind of your neighbour.  Should indeed work fine, so long as they have given you the correct password.
Are you getting an error message?
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 3 of 4
I just get ‘unable to join’ when I try to log in? That’s on all our devices, iPhones, fire stick etc
Message 4 of 4
@Langers123
I'd recheck the password with the Neighbour
Kind Regards
CJT80
