Message 1 of 3
Home phone - only one handset now works
I have just been transferred to wifi calling I did have 3 handsets, 2 downstairs and 1 up now the only one working is the one which is plugged into the router. Is there any way I can get them all to work, as if not I might as well scrap my home phone and just use my mobile. Any help would be much appreciated thanks
2 REPLIES 2
Message 2 of 3
Re: Home phone - only one handset now works
@RMT
Ask BT for a Digital Voice adapter, and then plug your existing phones into that, instead of plugging them into your master socket where they must have been originally.
https://www.bt.com/help/user-guides/phones/digital-voice/digital-voice-adapter
It should be provided free.
Message 3 of 3
Normally when moved to digital voice you get the choice of a free DV phone or a free adapter
