Message 1 of 8
Home phone
My master socket is in the hall close to the floor. There isn’t anywhere suitable to have a home phone. Is there any phones or solutions that would enable me to have a phone in the lounge without the need for wires trailing everywhere? Thanks.
7 REPLIES 7
Message 2 of 8
Re: Home phone
A cordless phone. There are countless brands and types to choose from, with and without answering machines.
Message 3 of 8
Re: Home phone
I currently have a cordless phone but it’s not suitable to have the base where the master socket is.
Message 4 of 8
Re: Home phone
do you have any extension sockets in other rooms?
do you have broadband?
where does the openreach phone line enter your home?
Message 5 of 8
Re: Home phone
I don’t have any extension sockets.
I do have broadband.
the line enters in the hall behind the front door.
Thanks.
Message 6 of 8
Re: Home phone
Then there is nothing you can do other than run a cable to an extension socket at the required location. Odd that the location is suitable for your router but not a phone base station.
When you eventually get moved to digital voice, your hub will become a DECT base station so you will have no need for a separate one.
Message 7 of 8
Re: Home phone
if you already have broadband (BT Retail customer?) then you must have the router/hub in the hall connected to master socket
Message 8 of 8
Re: Home phone
The router is on a wall bracket about 3 inches from the floor. Thanks for your help.
