Message 1 of 2
How do I get an engineer out to move my ONT up the wall a bit?
I need to move the ONT up the wall a bit to make space for some new pipe work which will run just above the skirting.
Can I book and engineer for this and any ideas as to the rough cost?
1 REPLY 1
Message 2 of 2
Re: How do I get an engineer out to move my ONT up the wall a bit?
You can book an engineer to do it. IIRC the minimum carge is £85. I'll try and find out tomorrow for you.
