Message 1 of 5
How to Purchase a 4G mini hub with Data plan
 this link (shown above) takes you to a page with no 4G mini Hub just mobiles. And this link https://business.bt.com/products/mobile/mobile-broadband/mini-hub-bt70/
Gives you only business plans. How can i buy 1 with a plan without being Halo. calling the BT Shop doesnt work either
4 REPLIES 4
Message 2 of 5
Re: How to Purchase a 4G mini hub with Data plan
They are listed on the BT.com website but under the tablets section, not sure why, data only plans would make more sense.
Have a look Here and pick the data required, between 3G to 30GB are the options.
Message 3 of 5
Thank you Richie,
Bit of a strange place to put them but it is what it is. You'd think the link on the website would take you straight there tho
Thanks again
Message 4 of 5
@Twinny
Does it have to be a mini hub?
If it is only for emergency use, then fine, but you can also get a full size 4G hub with up to 500GB data here:
https://www.bt.com/broadband/4g-hub
The USO team told me last week that there may be an unlimited option announced soon as well.
Message 5 of 5
Not really what I'm after but a big thank you, I have never seen this before
