Message 1 of 1
Parental controls - a bit more information please
Hi,
Parental controls on bt.com seem a bit broken - yesterday I had to tackle multiple problems:
1) xbox.com (and xbox live) were blocked on 'Light'
2) sometimes websites were blocked because of 'homework' even after I had removed all times, reset them, changed them to 2am-3am
3) Twitter was blocked (easily overcome with an exception but I had not blocked "social media")
4) Tiktok was blocked - I found this out whilst struggling to enable xbox
Sometimes a website will give you a blue screen saying why it is blocked and allowing you to override 'enable access' but sometimes it gives you the 'SSL certificate error' which is harder to overcome... I understand this may be a technical reason to prevent using a different DNS but an explanation would be good.
Sometimes changes are instance (add a website that is never blocked) and sometimes they take an unknown time (turning parental controls off, for instance, or changing 'customised' filter to 'light').
I found the best solution to enabling xbox live was to 'disable parental controls for 1 hour' and then switch parental controls off, and just hoped they actually ended before the hour was up.
I now want to switch them on again but with less problems, and I think I am not alone here. I cannot see how twitter should be blocked if I allow 'social media', nor xbox if I allow 'gaming'.
Ideally I'd be able to override the DNS on the smarthub, without a second DHCP router, so I can use a non-BT parental controls system.
If the community here can help that's great but I'm aiming this at BT to explain.
