Message 1 of 5
How to connect a digital phone to a NEW Wi-Fi (previous one changed)
I have a digital voice handset which is connected to Wi-Fi. Needed to change the Wi-Fi, unsure how to connect the phone. There does not seem to be an obvious setting on the phone allowing me to do this, and  when I press the WPS button on the Smart Hub 2, nothing pops up on the phone handset.
Solution or ideas welcomed!
4 REPLIES 4
Message 2 of 5
Re: How to connect a digital phone to a NEW Wi-Fi (previous one changed)
DV phones connect to hub using DECT not wifi
Message 3 of 5
@DR1403
The phones do not use Wi-Fi, they use DECT. You would have to pair the new phone with the DECT base station in the Smart Hub 2. There is nothing to do with the Wi-Fi settings.
Message 4 of 5
Thanks Keith, now understood.
The issue was with one handset, it needed to be reset to factory settings to be able to re-connect with the Hub.
Message 5 of 5
Thanks - The issue was with one handset, it needed to be reset to factory settings to be able to re-connect with the Hub.
