Message 1 of 4
Huawei MT992 replace BT hub6 I’m a novice an help simplified would be really appreciated, the Lan n
I have Bt Hub 6 and bought a NETGEAR Nighthawk router but couldn’t get orange light to change white no Internet so I bought a Huawei MT992 modem to replace BT HUB but LAN light won’t come on . I am a real novice and would really appreciate any simplified help
thank you so much
3 REPLIES 3
Message 2 of 4
Re: Huawei MT992 replace BT hub6 I’m a novice an help simplified would be really appreciated, the La
Do you know how to connect the Huawei MT992 to the by hub 6 please
Message 3 of 4
your HH6 need to have a WAN port to connect modem
Message 4 of 4
That's not possible I don't think. You could try connecting it to the LAN port of the smart hub, but otherwise you need a cable router with a WAN port not an ADSL router.
