Message 1 of 5
Hub6 faulty, can I use old Hub5
I think my Hub6 is faulty. Can I just plug in my old Hub5 and obtain internet connection to my BT infinity account?
Many thanks
4 REPLIES 4
Message 2 of 5
Re: Hub6 faulty, can I use old Hub5
yes as long as not FTTP   should be just plug and play
Message 3 of 5
Thanks for prompt reply. I am FTTC so as my Hub5 is also flashing orange a call to BT required.  Only thought Hub6 was a problem as will flash orange  orange solid and purple without me doing anything. Have factory reset also
Message 4 of 5
have you checked connection by using the test socket with a filter just to make sure problem not your master faceplate or internal wiring that is causing the problem before phoning BT
Message 5 of 5
Yes, done all that. Mine is an openreach mk3 box. I have fitted a new mk3 box and still no good. Phone line works but a bit of a crackle so a telephone call to BT required.
Many thanks
