Message 1 of 3
Hybrid connect signal
Hi all
looking for a bit of advice regarding where to locate my hybrid connect device.
In the signal section of the device I see signal strength of between -95dBm and -114dBm. Which is the better signal as they both normally show 2 bars on the device
thanks
2 REPLIES 2
Message 2 of 3
Re: Hybrid connect signal
The lower the number the better the signal. -95dBm is the stronger signal.
Message 3 of 3
Thanks. @licquorice
