Message 1 of 7
Kindle
Hello
I have a  kindle that used to down load books  but for the last 12 months or so as ive
not used lt for sometime it will not download. I  still have spaces to download books it's
so annoying.
When I go to the settings its saying network not connected I'm not sure why its saying that.
Any tips or advice greatly received .
Jan 8
6 REPLIES 6
Message 2 of 7
Re: Kindle
Go into the network settings and select the Wifi Network that matches the network printed on your hub label and then enter the wireless password that is also printed on the label.
Message 3 of 7
Re: Kindle
Hi Licquorice (Distinguished Sage)
I've gone into Wf-Fi networks on the kindle it's saying Available wi-fi Networks (0)
Network : not connected  so I'm sorry it does not seem to ask which network  I'm not sure what to do next?
Message 4 of 7
Re: Kindle
Then either your wifi on the hub or the kindle is turned off or not working. Can you connect other devices to your hub by wifi ok? If so the problem would appear to be with the Kindle.
Message 5 of 7
Re: Kindle
Hi @Jan8   Are you sure that your Kindle is not in Aeroplane mode?
Message 6 of 7
connection not working on my kindle
I have no  wifi connection on my kindle  .
Message 7 of 7
Re: connection not working on my kindle
Did you check it isn't set to aeroplane mode?
