Message 1 of 6
I have two lines and two master sockets
So I have found that I have two master sockets and two lines coming too my property. I am wondering if one of these might be a better line maybe even fibre to the premises.
5 REPLIES 5
Message 2 of 6
Re: I have two lines and two master sockets
if you are a BT broadband customer then enter your phone number and post results
Message 3 of 6
Here’s the stats it gave me, when they transferred us to this address it took around a month as they couldn’t find the line. So a bit confused with the two boxes and two lines.
Featured ProductsDownstream Line Rate(Mbps) Upstream Line Rate (Mbps)Downstream Handback
Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in JumperHighLowHighLowVDSL Range A (Clean) Loneshade_0-1605019092497.gif
8074201967.3AvailableAvailable--VDSL Range B (Impacted) Loneshade_1-1605019092500.gif
8072.4201964.8AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
1000220--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 16--8 to 19.5AvailableAvailable--
Up to 16Up to 1.58 to 19.5AvailableAvailable--
Up to 7.5--7 to 8AvailableAvailable--
2----AvailableAvailable--
2----Available----
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
U
27-10-2020
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
Y
Message 4 of 6
that shows FTTC is available but not FTTP   FTTPoD is not the same and more business orientated
Message 5 of 6
Okay then, could that be because of the phone line provided to us if it’s the wrong line. Just a bit confused as to why there are two lines coming in?
Message 6 of 6
I don't know why there are 2 line unless someone was running a business on 1 and residential on the other  your phone number show what is available and there is no FTTP available to you  the other line is more than likely connected to same street cabinet
