Message 111 of 124
Re: IP camera
Okay, I'm going to send this link to cam secure so they can see that it is all working . There's no need for them to get back to me and tell me that they haven't got the correct settings.
Message 112 of 124
Re: IP camera
I have removed my text overlay, as I am now using direct to disc recording which avoids re-encoding an using up CPU.
Audio can be very noisy when box is occupied.
Message 113 of 124
Re: IP camera
By all means pass on the link to them. They should be able to access your own stream via your hostname, as I can.
I can restrict the frame rate, and also change the upload priority on my server, as I am using a TP Link router.
Message 114 of 124
Re: IP camera
If this needs a lot more discussion, I will send you a private message which has one of my email addresses that I use exclusively for communicating with forum members.
Message 115 of 124
Re: IP camera
Thanks Keith. All I need is for them to be able to see that it is working. I'm not going to be looking at it, so it should be quite simple.
Message 116 of 124
Re: IP camera
I will see if they login into my stream, as Blue Iris keeps a log of IP addresses.
I could only see your IP logged in. Now logged off.
07/02/2021 12:36:02 demo 86.191.5.202: Logout, 13:13
Message 117 of 124
Re: IP camera
Brilliant, thank you.
I've been trying to get this CCTV to work. I know that you haven't got NVR box. However, have you any idea how I could reassign the original IP address to the box? I changed it stupidly and I think that's what's causing all the problems.
Message 118 of 124
Re: IP camera
You may find it easier if you create a new and shorter host name, just for them to use, as they would be the only one needing it.
Message 119 of 124
Re: IP camera
Not really, I would have thought it would use DHCP, and get the details from the home hub, which is why its odd that its getting the wrong subnet.
Can you let it use automatic (DHCP)?
I am wondering if it would be better to continue the discussion via email? You are not allowed to post email addresses here, but I can send mine to you via private messaging. I have done this with a couple of other members, to save posting on this forum.
Message 120 of 124
Re: IP camera
Yes we can do email. Do you not do Facebook?
