Message 1 of 5
Incoming calls going direct to voicemail
As far as I am aware I haven't changed anything but my phone is not ringing and all incoming calls going direct to voicemail.   I have an android phone Samsung S10, something happened like this a while ago I think but can't remember what to do to resolve it.
Thanks in advance.
4 REPLIES 4
Message 2 of 5
Re: Incoming calls going direct to voicemail
In the Calls app menu (3 vertical dots probably at top right) go to Settings > Calls > Call forwarding > make sure "Always forward" is set to Off.
Message 3 of 5
Hi thanks for that.  Under Call forwarding it shows (which is under Supplementary Services):
Always Forward - no number set
Forward when busy - forward calls to +44 795xxxxxxx
Forward when unanswered  - as above
Forward when unreachable - as above
Message 4 of 5
If it's not Call Forwarding have you tried rebooting your phone? Sometimes switching to airplane mode and back again is sufficient. I get the problem occasionally and a reboot or airplane mode fixes it.
Message 5 of 5
Just come off phone to BT  and she said she had reset something at their end and it worked.  When I turned off and on last night it didn't clear it.  Will try and remember about switching to Airplane Mode in case it happens again.
