Message 1 of 5
Incomplete order details
Hi,
I ordered today BT Fibre and the delivery address for the equipment and I assume the address for the engineer to attend to is also incomplete, is missing a letter and there are 3 flats in the building.
I managed to change the billing address, but, will that be enough? Can the delivery address and the address to attend to be updated?
Thank you!
4 REPLIES 4
Message 2 of 5
Re: Incomplete order details
This is a customer help customer forum and your post does not go to BT.  You need to phone 150 to get it changed
Message 3 of 5
Ok, thank you.
Equipment has not been installed yet line/broadband has not been activated yet, will this number "150" work from any network, or only from BT one?
Thank you!
Message 4 of 5
@VladRosetwrote:
Ok, thank you.
Thank you!
0800 800 150 will work from any mobile
Message 5 of 5
Ok, thanks!
