Message 1 of 2
Interleaving On, Request for Fast Path Please - DLM RESET
Hi,
So ive purchased billion 8800nl r2. Been using it to monitor my stats. Currently have Broadband VDSL with BT.
Noticed i have an interleaving depth of 8 on my download which means im not on Fast Path.
Could i please kindly ask the mods for my connection is switched to fast path / DLM reset?
My stats:
xDSL
ModeVDSL2
Traffic TypePTM
StatusUp
Link Power StateL0
 DownstreamUpstream
Line Coding (Trellis)OnOn
SNR Margin (dB)6.615.3
Attenuation (dB)11.50.0
Output Power (dBm)13.11.4
Attainable Rate (Kbps)8250929077
Rate (Kbps)7978019999
B (# of bytes in Mux Data Frame)243237
M (# of Mux Data Frames in an RS codeword)11
T (# of Mux Data Frames in an OH sub-frame)042
R (# of redundancy bytes in the RS codeword)1016
S (# of data symbols over which the RS code word spans)0.09740.3781
L (# of bits transmitted in each data symbol)208655374
D (interleaver depth)81
I (interleaver block size in bytes)254127
N (RS codeword size)254254
Delay (msec)00
INP (DMT symbol)50.000.00
OH Frames00
OH Frame Errors00
RS Words13366283234559246
RS Correctable Errors35771
RS Uncorrectable Errors00
HEC Errors00
OCD Errors00
LCD Errors00
Total Cells5013888270
Data Cells264326890
Bit Errors00
Total ES00
Total SES00
Total UAS2727
1 REPLY 1
Message 2 of 2
Re: Interleaving On, Request for Fast Path Please - DLM RESET
Latency is controlled automatically by the DLM and you will not get a reset unless you had line connection problems and not just for latency
not like previous adsl where  the mods were able to change latency
