Message 1 of 4
Intermitent Wifi Problem - Smart Hub 2
Hi Everyone I'm having trouble with my wifi on my Smart Hub 2.
The Broadband Connection is fine, but using devices i.e Mobile Phone or Ipad the Wi-Fi Drops out.
Any ideas how I can fix this?
Rob
3 REPLIES 3
Message 2 of 4
Re: Intermitent Wifi Problem - Smart Hub 2
Make sure you have turned off smart setup.
Try changing WiFi channels maybe using a WiFi analyser on mobile to find best or free channel
Message 3 of 4
BT at that time refreshed the connection and the problem has come back.
What Wifi Channel should I be looking at?
EDIT - did a factory reset of the hub and the wi-fi has come back on so I know it's a setting that needs adjusting?
Message 4 of 4
If you use a WiFi analyser on your phone you should see the channels in use near you and you want to change your channels to a free channel or least congested channel where your signal is strongest
