Message 1 of 2
Hub 6
just got hub 6 and can’t get my hp 3050 printer to connect with it.  Troubleshooter says there is no ssid found.  Printer is offline and I can’t get it to work with won or anything else.  Any idea what I can do or am I going to have to buy a new printer.  All very complicated it seems and it is the wireless connection that is not working.
1 REPLY 1
Message 2 of 2
Re: Hub 6
have you turned of smart setup
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
have you split the networks
https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/i-want-to-improve-my-wi-fi/how-d...
then try factory reset printer.
now try and connect to the 2.4ghz network which if you split as above should have a different SSID to the 5ghz
