Message 1 of 8
Intermittent Drops - Multiple Engineers, No Resolution
Hi all
Please can anyone advise if there's anything of concern indicated by the below?  Our internet keeps dropping and we've had numerous engineers out, nothing seems to be fixing the problem.  They haven't yet changed the overhead lines but we've had multiple engineers tell us that's probably what is needed.
Noise Line Test doesn't come up completely silent, there's this quiet humming noise (but it's not crackling etc).  We've had a few engineers claim they heard noise but they've fixed the issue.  Another engineer is coming out soon (our 8th or 9th at this point).
DSL uptime:0 days,01 Hours39 Mins21 Secs
Data rate:10 Mbps / 54.999 Mbps
Maximum data rate:27.487 Mbps / 59.910 Mbps
Noise margin:17.9 / 6.9
Line attenuation:10.8 / 16.3
Drops look like this on the technical log:
08:18:06, 29 Sep.
Lan IPv6 Neighbour Discovery events: NEIGHBOR_SOLICIT
08:18:05, 29 Sep.
WHW INFO A station STA(FE:0B:69:1D:6A:C2) leave WHW infrastructure
08:18:04, 29 Sep.
SIP WAN DOWN
08:18:04, 29 Sep.
WAN Sensing Auto sensing Complete, interface selected
08:18:04, 29 Sep.
WAN Sensing Auto sensing Running
08:18:03, 29 Sep.
WHW INFO A station (SmartHub2)IF[2.4G](78:DD:12:13:E2:93):STA(FE:0B:69:1D:6A:C2)(Legacy Device) join WHW infrastructure
08:18:03, 29 Sep.
08:18:02, 29 Sep.
08:18:02, 29 Sep.
WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
08:18:02, 29 Sep.
DHCP device Connected: 192.168.1.121, fe:0b:69:1d:6a:c2, Charlies
08:18:02, 29 Sep.
LAN [ADD] ARP 192.168.1.121 with fe:0b:69:1d:6a:c2 from br0(wl0)
08:18:02, 29 Sep.
ARP [add] br0(wl0) 192.168.1.121 fe:0b:69:1d:6a:c2
08:18:01, 29 Sep.
PPP: Stopped PPP daemon(0,1,5)
08:18:01, 29 Sep.
PPP LCP Send Termination Request (User request)
08:18:01, 29 Sep.
PPP: IPCP down
08:18:01, 29 Sep.
PPP: LCP down
08:18:01, 29 Sep.
DSL Link Down: duration was 629 seconds
08:17:54, 29 Sep.
WHW INFO A station (SmartHub2)IF[5G](78:DD:12:13:E2:92):STA(FE:0B:69:1D:6A:C2)(Legacy Device) join WHW infrastructure
08:17:54, 29 Sep.
08:07:09, 29 Sep.
SIP WAN DOWN
08:07:08, 29 Sep.
08:07:07, 29 Sep.
LAN [ADD] ARP 192.168.1.121 with fe:0b:69:1d:6a:c2 from br0(wl1)
08:07:07, 29 Sep.
ARP [add] br0(wl1) 192.168.1.121 fe:0b:69:1d:6a:c2
08:07:07, 29 Sep.
5G Client disassociate from fe:0b:69:1d:6a:c2 (IP=192.168.1.121) RSSI=0, Rate=0Mbps
08:07:05, 29 Sep.
SIP WAN DOWN
08:07:05, 29 Sep.
08:07:05, 29 Sep.
08:07:03, 29 Sep.
08:07:03, 29 Sep.
08:07:03, 29 Sep.
08:07:02, 29 Sep.
08:07:02, 29 Sep.
08:07:02, 29 Sep.
08:07:02, 29 Sep.
08:07:02, 29 Sep.
PPP: IPCP down
08:07:02, 29 Sep.
PPP: LCP down
08:07:02, 29 Sep.
DSL Link Down: duration was 3711 seconds
08:06:52, 29 Sep.
08:06:52, 29 Sep.
08:06:49, 29 Sep.
08:06:36, 29 Sep.
WHW INFO A station (Wi-Fi Disc 08)IF[5G](0C:8E:29:0D:EE:0A):STA(FE:0B:69:1D:6A:C2) join WHW infrastructure
7 REPLIES 7
Message 2 of 8
Re: Intermittent Drops - Multiple Engineers, No Resolution
A line doesn't have to have crackling on it to be noisy. However, if you are using a cordless handset then a dull hum is normal, that's why a corded phone is always recommended (it will also work during a power cut).
Message 3 of 8
Thanks Pippin - this was from a corded phone, so imagine that would be noise?
Just had another drop during an important work call 😞
DSL uptime:0 days,00 Hours03 Mins46 Secs
Data rate: 10 Mbps / 54.999 Mbps
Maximum data rate: 28.401 Mbps / 69.427 Mbps
Noise margin: 18.5 / 9.7
Line attenuation: 11.4 / 16.8
Signal attenuation: 11.4 / 21.3
11:05:26, 29 Sep.
CWMP: HDM socket closed successfully.
11:05:26, 29 Sep.
CWMP: HTTP authentication success from pbthdm.x.x.x
11:05:26, 29 Sep.
CWMP: HDM socket opened successfully.
11:05:26, 29 Sep.
CWMP: session completed successfully
11:05:26, 29 Sep.
11:05:25, 29 Sep.
11:05:25, 29 Sep.
11:05:25, 29 Sep.
11:05:24, 29 Sep.
CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
11:05:24, 29 Sep.
CWMP: Session start now, server: https://pbthdm.x.x.x, Event code: 4 VALUE CHANGE
11:05:24, 29 Sep.
CWMP: Initializing transaction for event code 4 VALUE CHANGE
11:04:22, 29 Sep.
SIP WAN UP
11:04:20, 29 Sep.
NTP synchronization success
11:04:20, 29 Sep.
NTP Server: ntp.homehub.btopenworld.com
11:04:05, 29 Sep.
11:04:05, 29 Sep.
11:04:04, 29 Sep.
WAN IPv6 Global unicast prefix / length: 2a00:23c4:32a7:c700::/56
11:04:04, 29 Sep.
WAN IPv6 Global unicast address allocated: 2a00:23c4:32a7:c700::1/64
11:04:04, 29 Sep.
WAN DHCPv6 events: BOUND
11:04:04, 29 Sep.
NTP synchronization start
11:04:03, 29 Sep.
WAN DHCPv6 events: INIT
11:04:03, 29 Sep.
11:04:03, 29 Sep.
11:04:03, 29 Sep.
Success - secondary DNS servers
11:04:03, 29 Sep.
WAN connection WAN2_INTERNET_PTM connected
11:04:03, 29 Sep.
PPP: IPCP up
11:04:02, 29 Sep.
PPP IPCP Receive Configuration ACK
11:04:02, 29 Sep.
PPP IPV6CP Receive Configuration ACK
11:04:02, 29 Sep.
PPP IPCP Send Configuration Request
11:04:02, 29 Sep.
PPP IPCP Receive Configuration NAK
11:04:02, 29 Sep.
PPP IPCP Send Configuration ACK
11:04:02, 29 Sep.
PPP IPCP Receive Configuration Request
11:04:02, 29 Sep.
PPP IPV6CP Send Configuration ACK
11:04:02, 29 Sep.
PPP IPV6CP Receive Configuration Request
11:04:02, 29 Sep.
PPP IPV6CP Send Configuration Request
11:04:02, 29 Sep.
11:04:02, 29 Sep.
PPP: CHAP authentication succeeded
11:04:02, 29 Sep.
PPP CHAP Receive success : authentication successful
11:04:02, 29 Sep.
PPP CHAP Receive Challenge
11:04:02, 29 Sep.
PPP: LCP up
11:04:02, 29 Sep.
PPP LCP Receive Configuration ACK
11:04:02, 29 Sep.
PPP LCP Send Configuration ACK
11:04:02, 29 Sep.
PPP LCP Receive Configuration Request
11:04:01, 29 Sep.
PPP LCP Send Configuration Request
11:04:01, 29 Sep.
PPP: Received PADS
11:04:01, 29 Sep.
PPP: Sending PADR
11:04:01, 29 Sep.
PPP: Received PADO
11:04:01, 29 Sep.
PPP: Sending PADI
11:03:51, 29 Sep.
PPP: Sending PADI
11:03:46, 29 Sep.
PPP: Sending PADI
11:03:43, 29 Sep.
DSL Link Up: Down Rate=54999kbps, Up Rate=10000kbps; SNR Margin Down=9.9dB, Up=18.7dB
11:03:41, 29 Sep.
PPP: Sending PADI
11:03:36, 29 Sep.
PPP: Starting PPP daemon
11:03:35, 29 Sep.
WAN Auto-sensing detected port DSL WAN
11:03:04, 29 Sep.
SIP WAN DOWN
11:03:03, 29 Sep.
11:03:03, 29 Sep.
11:03:02, 29 Sep.
11:03:01, 29 Sep.
11:03:01, 29 Sep.
11:03:00, 29 Sep.
11:03:00, 29 Sep.
11:03:00, 29 Sep.
PPP: IPCP down
11:03:00, 29 Sep.
PPP: LCP down
11:03:00, 29 Sep.
DSL Link Down: duration was 9870 seconds
11:02:50, 29 Sep.
admin timeout from 192.168.1.92
10:49:46, 29 Sep.
WHW INFO A station (Wi-Fi Disc 08)IF[ETH](00:00:00:00:00:00):STA(2C:54:91:7A:26:7F) join WHW infrastructure
10:49:36, 29 Sep.
ARP [add] br0(wds0.4.1) 192.168.1.246 2c:54:91:7a:26:7f
10:49:36, 29 Sep.
WHW INFO A station STA(2C:54:91:7A:26:7F) leave WHW infrastructure
10:49:36, 29 Sep.
ARP [del] br0 192.168.1.246 2c:54:91:7a:26:7f
10:33:52, 29 Sep.
WHW INFO A station STA(1A:C1:81:2C:F2:D2) leave WHW infrastructure
Message 4 of 8
And again - each time I get kicked off my work VPN so takes a good 5 minutes out of my day.
DSL uptime:0 days,00 Hours00 Mins49 Secs
Maximum data rate:29.060 Mbps / 71.374 Mbps
Noise margin:19.2 / 10.3
Line attenuation:10.6 / 16.1
Signal attenuation:10.6 / 20.3
11:22:26 29 Sep. CWMP: HDM socket closed successfully.
11:22:26 29 Sep. CWMP: HTTP authentication success from pbthdm.x.x.x
11:22:26 29 Sep. CWMP: HDM socket opened successfully.
11:22:26 29 Sep. CWMP: session completed successfully
11:22:25 29 Sep. CWMP: HTTP authentication success from pbthdm.x.x.x
11:22:25 29 Sep. CWMP: HDM socket opened successfully.
11:22:24 29 Sep. CWMP: Server URL: https://pbthdm.x.x.x; Connecting as user: ACS username
11:22:24 29 Sep. CWMP: Session start now server: https://pbthdm.x.x.x
11:22:24 29 Sep. CWMP: Initializing transaction for event code 4 VALUE CHANGE
11:21:29 29 Sep. SIP WAN UP
11:21:19 29 Sep. NTP synchronization success
11:21:19 29 Sep. NTP Server: ntp.homehub.btopenworld.com
11:21:05 29 Sep. WAN Sensing Auto sensing Complete interface selected
11:21:05 29 Sep. WAN Sensing Auto sensing Running
11:21:03 29 Sep. NTP synchronization start
11:21:03 29 Sep. WAN IPv6 Global unicast prefix / length: 2a00:23c4:32a7:c700::/56
11:21:03 29 Sep. WAN IPv6 Global unicast address allocated: 2a00:23c4:32a7:c700::1/64
11:21:03 29 Sep. WAN DHCPv6 events: BOUND
11:21:03 29 Sep. WAN Sensing Auto sensing Complete interface selected
11:21:03 29 Sep. WAN Sensing Auto sensing Running
11:21:03 29 Sep. Success - secondary DNS servers
11:21:03 29 Sep. Success - primary DNS servers
11:21:03 29 Sep. WAN connection WAN2_INTERNET_PTM connected
11:21:03 29 Sep. WAN DHCPv6 events: INIT
11:21:02 29 Sep. PPP: IPCP up
11:21:02 29 Sep. PPP IPCP Receive Configuration ACK
11:21:02 29 Sep. PPP IPV6CP Receive Configuration ACK
11:21:02 29 Sep. PPP IPCP Send Configuration Request
11:21:02 29 Sep. PPP IPCP Receive Configuration NAK
11:21:02 29 Sep. PPP IPCP Send Configuration ACK
11:21:02 29 Sep. PPP IPCP Receive Configuration Request
11:21:02 29 Sep. PPP IPV6CP Send Configuration ACK
11:21:02 29 Sep. PPP IPV6CP Receive Configuration Request
11:21:02 29 Sep. PPP IPV6CP Send Configuration Request
11:21:02 29 Sep. PPP: CHAP authentication succeeded
11:21:02 29 Sep. PPP CHAP Receive success : authentication successful
11:21:02 29 Sep. PPP CHAP Receive Challenge
11:21:02 29 Sep. PPP: LCP up
11:21:02 29 Sep. PPP LCP Receive Configuration ACK
11:21:02 29 Sep. PPP LCP Send Configuration ACK
11:21:02 29 Sep. PPP LCP Receive Configuration Request
11:21:01 29 Sep. PPP LCP Send Configuration Request
11:21:01 29 Sep. PPP: Received PADS
11:21:01 29 Sep. PPP: Sending PADR
11:21:01 29 Sep. PPP: Received PADO
11:21:01 29 Sep. PPP: Sending PADI
11:20:56 29 Sep. PPP: Sending PADI
11:20:51 29 Sep. PPP: Sending PADI
11:20:46 29 Sep. PPP: Sending PADI
11:20:43 29 Sep. DSL Link Up: Down Rate=54999kbps Up Rate=10000kbps; SNR Margin Down=10.3dB
11:20:41 29 Sep. PPP: Sending PADI
11:20:36 29 Sep. PPP: Starting PPP daemon
11:20:35 29 Sep. WAN Auto-sensing detected port DSL WAN
11:20:12 29 Sep. SIP WAN DOWN
11:20:09 29 Sep. SIP WAN DOWN
11:20:09 29 Sep. WAN Sensing Auto sensing Complete interface selected
11:20:09 29 Sep. WAN Sensing Auto sensing Running
11:20:07 29 Sep. WAN Sensing Auto sensing Complete interface selected
11:20:07 29 Sep. WAN Sensing Auto sensing Running
11:20:07 29 Sep. WAN connection WAN2_INTERNET_PTM disconnected.[ERROR_NO_CARRIER]
11:20:06 29 Sep. PPP: Stopped PPP daemon(01
11:20:06 29 Sep. PPP LCP Send Termination Request (User request)
11:20:05 29 Sep. PPP: IPCP down
11:20:05 29 Sep. PPP: LCP down
11:20:05 29 Sep. DSL Link Down: duration was 990 seconds
11:19:01 29 Sep. DHCP device Connected: 192.168.1.130 1a:c1:81:2c:f2:d2
11:19:01 29 Sep. LAN [ADD] ARP 192.168.1.130 with 1a:c1:81:2c:f2:d2 from br0(wl0)
11:19:01 29 Sep. ARP [add] br0(wl0) 192.168.1.130 1a:c1:81:2c:f2:d2
11:18:40 29 Sep. WHW INFO A station (SmartHub2)IF[5G](78:DD:12:13:E2:92):STA(1A:C1:81:2C:F2:D2)(Legacy Device) join WHW infrastructure
Message 5 of 8
Hi @CluedoWine,
Thank you for posting. I'm sorry you're having problems with your connection. I know how frustrating working from home with an unstable connection can be. If you send me your details, I can run a few checks on your line and hopefully help to get the service repaired.
I have sent you a private message with instructions on how to contact me.  You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
PaddyB
Message 6 of 8
Hi Paddy
Sorry for delayed response - our matter is now being treated as a 'priority' so hopefully will be fixed quickly, especially after we had the engineer apparently cancel the call-out yesterday because they saw no issues on the line and as this issue has now been ongoing for months with no resolution.
Any general information so we can better advocate for ourselves would be useful - e.g. is the noise margin I noted above too high (indicating high resistance fault) and do the log excerpts suggest an issue with the phone line rather than anything internal?
None of the engineers seem to listen or care when we detail what's been going on, never have the notes from the previous visits to show what work has already been done and just rely on a 2 minute test that they say shows 'no issue', even though I've stated multiple times it's an intermittent problem and can go a day (or once 6 days) without fault, whereas other days (like Tuesday) it dropped well over 30 times (stopped counting at that point).
Best
CW
Message 7 of 8
your high noise margin is normal and is due to you being on fibre 1 with 55mb down speed and attainable in 70's.  if you were on fibre 2 then speed would be nearer attainable and noise margin would be at 6db
Message 8 of 8
Thanks ImJolly, appreciate the reply!
