Message 11 of 13
Re: Landline after FTTP
@pedrwrote:
Why are BT billing for line rental then?
This arrangement was set up many years ago, possibly before LLU (and with Tiscali before it became Talk Talk).
Solus line and/or carrier pre-select would be my guess.
Solus line - you pay line rental to BT, you pay TalkTalk for the broadband
Carrier pre-select - you pay line rental to BT, you pay another for the call usage
Both were quite common years back, gradually phased out now and no longer a product sold because providing support was an issue.
Message 12 of 13
Thanks - those terms helped me make sense of the situation.
If that's the set-up, is it likely to be relatively simple to order Fibre 2 from BT, and leave BT to disentangle the TalkTalk elements? I'd like to keep the same number, and probably keep a copper landline connection if possible.
Message 13 of 13
@pedr
Keeping the number maybe dependant on who provided it originally.
If it's NOT BT it could be lost in the transfer to another provider.
For a more technical/overall reply to your question you may want to try Broadband Forums :: think broadband they provide independent advice.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
