Message 1 of 2
Latency change after open reach work
I had been having disconnects with my broadband. So openreach attended 3 days ago
latency has now increased from 15ms to 30ms at best and fluctuating to 600ms randomly.
I think they changed the profile??
here is a screencap of router settings.
anything noticeable or advice would help before I call tomorrow
1 REPLY 1
Message 2 of 2
Re: Latency change after open reach work
these stats look good apart from short connection time  your connection speed is almost at attainable with noise margin at normal 6db  if you can get a stable connection for 7/10 days then DLM will normally reduce your noise margin down to 3db giving a slight boost to connection speed
