Message 1 of 7
Lies or ignorance?
My Hub is refusing to port forward for IPSEC NAT, IKE and ESP so BT sent a replacement.
There is something badly wrong with the replacement - bringing up the hub manager told me that there was no point in proceeding.
So I get on the phone to BT who as usual treat me like a complete idiot. I explain the problem in simple terms, nothing is working in the hub manager, none of the links work and the page hasn't even rendered properly.
I get asked if the hub is connected to the phone line - I reply no, I want to configure it before I connect it.
BT response, you cannot use the hub manager until you connect to the phone line.
I tell her that in 30 or so years of configuring networking equipment I have never come across a unit that cannot be configured offline. I'm told sorry that's how it works, if you don't connect it we can't help you.
6 REPLIES 6
Message 2 of 7
Re: Lies or ignorance?
have you tried a factory reset by pressing recessed button on back and holding for 20/30 secs until lights flash?
Like you I prefer to set my hub preferences before I connect it to the internet - makes life easier
Message 3 of 7
Hard reset several times!
Message 4 of 7
then phone 150 and get replacement
Message 5 of 7
That is exactly what I was trying to do. I'm giving up on this and buying a proper router.
Message 6 of 7
Make sure you buy the correct device, as many people make the mistake of simply buying a router, when they need a modem/router combination.
Message 7 of 7
Thanks. I've owned just about every piece of kit from the original GPO 300 baud modem which was as big a printer, acoustic couplers and BT kit since Highway, they have all been rubbish so it is now time to get something solid.
