Message 1 of 4
Line in garage
Hi  Can some one tell me who owns the very old landline wire that is in my garage . The garage door was replaced and the wire was on the top panel of the frame . The wire broke away from a very old connector box , but i could see what was wrong and sorted it .   So who owns the land line ?    Thanks for your help
3 REPLIES 3
Message 2 of 4
Re: Line in garage
openreach own the line and you need to contact them   there is no link from this BT Retail customer forum
https://www.openreach.co.uk/orpg/home/submitFeedbackLoggedInUser.do
Message 3 of 4
Re: Line in garage
Are you a customer of BT?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 4
Re: Line in garage
No iam not .  I am with Plusnet , i now know what to do . Thanks for your help.
