Message 1 of 8
Line stats
Do these stats look ok.
My tp link says 34998 and 6.6 up and on ADSL checker it's this
7 REPLIES 7
Message 2 of 8
Re: Line stats
you need to post more information about your connection so stats from tplink
have you been having problems with router dropping connection?
any noise on quiet line test?
Message 3 of 8
Re: Line stats
I suspect your tinkering about with routers has incurred the wrath of DLM.
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Adding-gaming-router/td-p/2159427
Message 4 of 8
Re: Line stats
Nope just plugged into the back. I know several router reboots would cause dlm to kick in so don't do it.
Message 5 of 8
Re: Line stats
How about you posting some connection stats then rather than a screenshot of an estimate and a  download speed reported by your router.
To ask about line stats and not show them does not beg an answer. Once you post them then someone will be able to advise.
Message 6 of 8
Re: Line stats
Message 7 of 8
Re: Line stats
What about quiet line test?
The stats are very brief - what about internet connection time not system uptime
Message 8 of 8
Re: Line stats
Looks like the DLM system has put you on a banded profile in response to errors on your line, at the top of the up to 35 Meg band of these VDSL Banded Profiles . The QLT is a must.
