Message 1 of 53
Internet speed
Hi,
I have a job which requires an internet upload speed of 9 mpbs.  My account says I have:
Your normal available download speed will be between 31-49 Mbps
Your normal available upload speed will be between 6-9 Mbps
However, the speed barely gets above 6.
What can I do to increase its performance please?
I have cleared browsers, files, defragged etc and used a direct ethernet cable but to no avail.
Advice is welcome B-)
52 REPLIES 52
Message 2 of 53
Re: Internet speed
The speeds quoted by BT are connection speeds so up speed is 6/9mb so your actual upload speed will be less so 6mb seems about right
please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 53
Re: Internet speed
Thank you for your reply.  Here are the stats so far:
16:52 6.79
17:16 6.74
17:32 6.82
17:44 6:73
17:50 6.71
18:46 6.70
It seems that the speed is slowing in off peak/low network traffic times today.
Do you know if there is an account available domestically that offers a speed of 9mbps or above?
Many thanks
Kind regards,
Chris
Message 4 of 53
Re: Internet speed
The problem is the laws of physics and distance from the cabinet I'm afraid, not one of account.
The stats requested is a screenshot of your hub stats page please.
Message 5 of 53
Re: Internet speed
yes the stats are from my device.
My laptop is about 24 inches from the hub and the readings are the same on wifi and ethernet
Message 6 of 53
Re: Internet speed
You haven't given your connection stats only the speed reported.
Message 7 of 53
Re: Internet speed
Your broadband speed is governed by the distance of your house to the green cabinet that supplies the signal.
We need to see a screenshot of all the information from Advanced Settings > Technical Log > Information to take a view if your speed is as good as it is going to get.
Message 8 of 53
Re: Internet speed
thank you. There is a page full - which part of the stats do you need?
Message 9 of 53
Re: Internet speed
A screenshot of the whole page, or at least the top part of the page showing data rate, noise margin etc. please.
Message 10 of 53
Re: Internet speed
Thank you... here it is:
eatured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean) chriso57_0-1620239055633.gif
54.43510.77.132.4AvailableAvailable--
53.23510.66.730AvailableAvailable--
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 4.5--3.5 to 5.5AvailableAvailable--
Up to 4.5Up to 0.53.5 to 5.5AvailableAvailable--
Up to 2--1 to 3.5AvailableAvailable--
1----AvailableAvailable--
1----Available----
Observed Speeds VDSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
32.4
7.2
2019-12-18
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
N
N
N
30-04-2021
Exchange Product Restrictions StatusFTTP Priority ExchangeWLR WithdrawalSOADSL Restriction
N
N
Y
