Message 11 of 17
Re: Lost Landline Number During Move
Thank you @Keith_Beddoe I will place an order now for the line, is there anything specific i need to request or ask?
Message 12 of 17
No, just place the order for the line. You will at some point, get an email confirming the order, and it may tell you the number that has been allocated.
You must wait until it is actually working on the new number, before you request the re-number.
You can place the order here.
https://www.bt.com/landline/
Depending on how many calls are likely to be made, you may wish to choose a calls package, as the default is PAYG at 20p a minute.
Message 13 of 17
Thank you for your help @Keith_Beddoe I have now placed the order. Install date is scheduled for 17 Feb 21.
Do i post her or renumbering or i need to call bt customer service?
Message 14 of 17
Try customer services first, if you encounter any issues, then help can be offered here.
Please keep this thread updated.
Message 15 of 17
Hi @Keith_Beddoe
All went well and I got the number back!!
Line was reconnected yesterday, after it was done I spoke to CS who allocated and arranged the renumbering for today (18 Feb) this was actioned by bt engineer Jeremy and a big thanks to him. All gone smoothly and all working.
Message 16 of 17
Excellent news 😀
Message 17 of 17
The engineer, if they visited, would be from Openreach not BT.
You can pass on thanks if you wish.
https://www.openreach.com/thank-an-engineer-form
