Message 11 of 14
Re: Master Socket and Networking
Ah, now thats making more sense. Thank you
So, going forward...I'm looking to order 2x mk4 filtered faceplates, one for each line coming in. I should then be able to simply connect my blue and blue/white wires of the Cat5 to the AB points on my side of the box. And these should in turn provide me with 2 new filtered data points where I actually need them. Without any real loss to performance.
am I understanding this correctly?
Message 12 of 14
They will be UNfiltered rather than filtered. Broadband requires the unfiltered signal, it is the phone that has the filtered signal.
Message 13 of 14
Oh really, I think this is where I'm getting confused. I was lead to believe that this would give me an already filtered broadband signal straight from the network, filtered of  noise.
Would i have to add another filter at the other end, wouldnt this effect the broadband signal?
Message 14 of 14
The purpose of the filter is to prevent the broadband signal interfering with the voice signal, hence if you have a filtered master socket, broadband won't work at extension sockets wired from the filtered terminals 2&5 and require an unfiltered signal from the data extension terminals. Filtering does absolutely nothing with the broadband signal and is only required for phones.
