Message 1 of 4
Master socket
Can I get the master socket relocated during the installation as it is next to my bed and it would be easier if it was in the living room.
3 REPLIES 3
Message 2 of 4
Re: Master socket
What package are you getting FTTP or FTTC?
if you are getting FTTP and also digital voice then the master  is not used
Message 3 of 4
Re: Master socket
I’m getting fibre
Message 4 of 4
Re: Master socket
FTTP and FTTC are both fibre packages but I assume your post 'I am getting fibre' suggests FTTP (FIBRE TO THE PREMISES) but are you also getting digital voice for phone? If getting DV then master socket is not used as phone connects to hub but if no DV then phone will need the master socket.
You need to check your order confirmation
