Message 1 of 6
Master socket
Suffered a lightning strike in my area which fried the router
 Bt replaced this ,but plugging it into the master socket (openreach 5c mk4)got no broadband
apparently my socket fried at the sane time
went to change socket straight swap for the front face plate first. No joy still no broadband
took the rear plate off and found two wires on the rear going to A&B one was solid blue and one appeared to be solid white changed the rear plate
put these into the clear block( three times) making sure they were fully pushed in
Still no broad band
mass of wires to the front of the plate which i assume are the old telephone cables and extensions(no longer required)
cannot for the life of work out why my new router and broadband still will not work
PS BT informs me there is nothing wrong with my libe
5 REPLIES 5
Message 2 of 6
Re: Master socket
provided you don't have digital voice can you get a dial tone of your corded phone
Message 3 of 6
Re: Master socket
Have no phone
Message 4 of 6
Re: Master socket
As far as i am aware the phone  cables are all now disconnected within the socket as i have not had a corded phone in years
its the two wires in the rear of the plate one is solid blue one appears solid white these are the two cables as fitted before it all went wrong
all i did was copy there pisition onto the new back plate snap down connector
Message 5 of 6
Re: Master socket
then you need to phone CS 03301234150 and report a fault
the most basic test is to see if dial tone but as you cannot do that you need to report broadband fault
Message 6 of 6
Re: Master socket
Hi @bobbase and thanks for posting.
I'm sorry for the late reply. Did you manage to get this sorted? Can you post back and let us know how you're getting on?
Cheers
David
