Message 1 of 2
Mixing BT advanced phone and old dect phones on hub
BT are sending me an advanced phone as i am going VoIP soon. Has anyone tried using a old dect phone plugged into the hub and link a new advanced phone wirelessly as well.
1 REPLY 1
Message 2 of 2
Re: Mixing BT advanced phone and old dect phones on hub
@TrevorT
There should not be an issue with this, however the BT Digital Voice phones use DECT and not wifi, and there is a DECT base station within the Smart Hub 2, so you may get a loss of performance as they might interfere with each other, unless your DECT base unit is situated well away from the home hub.
