Message 1 of 6
Mobile in Finland
I am visiting Finland with my adult son , our mobiles are on the same BT package, but his phone has not connected to the network here ?
So no calls or texts but he can connect to a local wifi , not no roaming data ?
Looking at my account it may want me to increase the spend cap but he has lots of data Tex and calls left in his allowence
His is a iphone 7
Any ideas please ?
5 REPLIES 5
Message 2 of 6
Re: Mobile in Finland
I think you need a spend cap above zero - have you tried
Message 3 of 6
No , should not have to do that has he has loads of calls etc , but will move it to a £ 5 and try
Message 4 of 6
I think you really need to have a positive spend limit to get the connection even though you may use your existing data and not actually spend anything
Message 5 of 6
Message 6 of 6
It's working, 🙂👍
Many many thanks Imjolly
