Message 1 of 3
Modem choice
Hello all,
I've got a BT Home Hub 5 which I want to replace with my mesh networked Netgear Orbis. The orbi is only a router though, and I need a modem that works with my BT DSL connection. The home hub can't act in model only mode, so I need a replacement device. Would the Hg612 3B that's used for fibre modem work? If so, is there an official store? (can only find online via ebay etc)
2 REPLIES 2
Message 2 of 3
Re: Modem choice
if you have fibre FTTC the the hg612 will be ok  ebay is best place
Message 3 of 3
Re: Modem choice
The HG612 will work with either fibre FTTC (VDSL) broadband or standard copper (ADSL) broadband. There is no 'official' source.
