Message 1 of 2
Modem router combo
I have a BT Smart Hub 2 which is connected to a Huawei 1-port modem (Huawai echolife hg8110h-20). Does my Smart Hub need to be connected to the modem or can I plug the fibre cable directly into the router? If not is there a product that I compatible with my set up that can act as both the modem and router?
1 REPLY 1
Message 2 of 2
Re: Modem router combo
@user90348123
No, you can only use the optical modem supplied, as its registered on the network,
You can however use your own router and connect that to the optical modem.
