Message 1 of 3
Modem
Hi can anybody advise how I can get a replacement for my hub modem
2 REPLIES 2
Message 2 of 3
Re: Modem
Are you using a separate modem to your hub?  If so then you can a secondhand one of eBay as they are nomlonger supplied
Message 3 of 3
Re: Modem
If it’s a separate modem you are after to replace the old BT ones there are several you can try.
Vigor 130 and 166, and the Zyxel vmg4005.
Many match up the chipsets to the cabinet and it’s important to note the Vigor 166 had issues as it’s new and the Zyxel is newish to the U.K. market but a friend runs it and is happy with its performance.
I did try the Vigor 166 back in February but it was giving me errors and I lost a lot of throughput and did try to work with Draytec support but at the time it was not resolved.
