Message 1 of 9
WiFi 6 Router/Modem for BT Fiber
Hi,
I am sure it has been asked and covered before but I couldn't find a definitive answer.
Are there any WiFi 6 plug n play router/modems on the market for use with BT Fiber 900?
8 REPLIES 8
Message 2 of 9
Re: WiFi 6 Router/Modem for BT Fiber
Message 3 of 9
Thank you, are those all modems too? So simply plug and play with bt?
Message 4 of 9
You would just have to configure the PPPoE settings which is very easy.
username of [email protected]
Password BT
Message 5 of 9
Thank you very much 👍🏻
Message 6 of 9
If you have Fibre 900 you don't need a modem, the ONT is the modem.
Message 7 of 9
@McG The Asus RT-AX88U is very popular.
Beware of Netgear devices, unless they have changed their stance they didn't support BT's /56PD implementation of IPv6
Message 8 of 9
I have a Netgear Orbi RBK750 and IPV6 works fine with BT. They seem to have updated the firmware for newer models to work with BT now.
Message 9 of 9
I use Fibre 900 and connected it using a Netgear RAX200 WiFi 6 router directly to the ONT but this frequently disconnected. I sent it back. I now use Unifi equipment and this has been very stable without a single drop out. You will only get faster WiFi6 speeds if your device supports WiFi6.
