Message 1 of 11
Moved BT Hub
We have BT 900 and have moved the router to a different location. Does it matter that we used CAT6 cable and didn’t use the proprietary red Ethernet cable included with the hub?
Because on the BT app it says we are using a third party hub with the CAT6 cable. We are also only getting wired speeds of about 90mbps.
10 REPLIES 10
Message 2 of 11
Re: Moved BT Hub
It should make no difference. I would look at a cable problem.
Message 3 of 11
Re: Moved BT Hub
The cables are wired right if that’s what you was meaning. It does say on some BT help sites that disconnection a few times can put you on a slower line. Which it has been disconnected.
Anonymous
Not applicable
Message 4 of 11
Re: Moved BT Hub
Is there a sharp bend in the cable where it plugs into the hub? if so it may not be making a good contact
Message 5 of 11
Re: Moved BT Hub
No it doesnt have a sharp bend in the cable
Anonymous
Not applicable
Message 6 of 11
Re: Moved BT Hub
Sounds like a faulty cable then
Message 7 of 11
Re: Moved BT Hub
It’s a brand new CAT6 cable
Message 8 of 11
Re: Moved BT Hub
Could still be faulty
Message 9 of 11
Re: Moved BT Hub
Is there any way to check if it’s faulty?
Anonymous
Not applicable
Message 10 of 11
Re: Moved BT Hub
Put the hub back where it was, using the cable supplied and re-check your speed. Then connect a laptop or PC to the hub using the suspect cable, run another speed test and compare the results
