Message 11 of 11
Re: Moved BT Hub
A cable tester, or put the hub back where it was a use the cable to connect a laptop/PC to a LAN port. Is the reduced speed a wired or wireless connection? You may have moved the hub to a location with increased wifi interference if testing with a wireless connection.
